huh...the usrt site says that they are cone pattern not pencil.
currently: 1987 944 NA 5spd, 250 lb hyper coils, 27 mm t bars, Koni, 968 m030 bars, full delrin, Audi I5 20VT, VEMS, Tilton, EFI Express, Seimens, Race Technologies
see the AAN/944 swap at Nina's 20VT
I contacted usrt yesterday and here is the reply that I received.
Thanks for the interest, LeRoy. The G550 are shorter than the AAN's original
injectors. However, they can be lengthened with what we call "unspacers".
Here's an example of what I'm referring to:
US Rally Team : Page Not Found - Engine, Fuel + Spark, Transmission, Decals, Water/Methanol Injection, Suspension, Exhaust, Forced Induction, Brake Systems, Fittings (AN + NPT),
Another option is to go with the Siemens 630cc injectors which will fit
directly. The spray pattern isn't quite as advanced, but it still works
great. What else may I share with you/let you know?
Are these the 006 injectors that you are talking about Gazza? I thought is was pretty cool that usrt actually recommended a cheaper unit then what I asked about.
