A little info about the engine first,
-MC block and crank
-Pauter rods
-JE 4valve Pistons
-7A head w/ modified 4 port water outlet
-7A cams
-LS2 truck ign coils
-S4 water pump
-S4 serp belt & accessories
-GSXR 750 individual throttle bodies w/ o-ringed shafts
-Balance tubes between runners to help idle vacuum, cylinder balance, and drivability issues w/ itb's
-Water cooled IC integrated into a 2" ID runner intake manifold/plenum
-60-1 turbo
-3" full ss Exhaust
-ss exhaust manifold
-82lb/hr injectors
-8860 standalone (EMS)
Im hoping for a little under 600hp crank and maybe just under 700 with a different turbo.
More random pics here, http://s240.photobucket.com/albums/ff267/rabemotorsports/
I had bought the head used a while back. The valve guides werent worn too badly so i installed new valves, seals, lapped them and called it good.
I found out later that the guides werent installed all the way down and the valve keepers were smashing into the seal and the guide. It wasnt enough to break things but it was enough to deform the seals. It also managed to destroy the hydraulic lifters to the point where they were frozen solid and hanging valves open.
I just got new guides installed/valvejob again and ended up going with the 2 piece solid lifters from eurospec. I used .015" clearance on the exhaust and .008 on the intakes. I found this from UrQ bently and figured it would be close enough.
The valvetrain is very noisy. Its about half as loud as the your a quart low on oil lifter tick these cars do. The clearance is obviously too much but i dont know by how much.
Basically asking if anyone has any BTDT on solid lifter valve clearance with a 20v 5cyl turbo engine.
Thanks in advance.
-MC block and crank
-Pauter rods
-JE 4valve Pistons
-7A cams
-S4 water pump
-60-1 turbo
-3" full ss Exhaust
-82lb/hr injectors
Thanks in advance.
