Help.... Any input would be great
  • s4kido
    • Aug 2009
    • 251
    • Home: Poland Current: United States
    As you all now i did a conversion on my coupe for the sweet turb motor from a URS4.. I have a post on here with the entire process.
    Everything is hooked up and its all correct.. I checked my timming like 4 times and its on the money...
    The motor would start and run but it would shake like crazy.. when i had the motor in the S4 it would be so quiet and no shakes at all... last night when playing around with fabricating the downpipe( i will have pictures up tonight) i put everything back together and now im not able to start it.. it cranks and all but i dont here the fuel pump kicking on... I check the fuse and its ok..
    Also i used a vag com to do a output check and the injectors wouldn't make any noise when it would be getting check, the isv, evap and n75 would...
