oil filter backet torque specs
  • ShadowofBob
    • Apr 2007
    • 130
    Just wondering if anyone could post up the tq specs for the oil filter bracket bolt and the M6 bolts(I'm assuming its 7 ft/lb, but want to be sure) that hold the plate that contains the spring/piston for the oil cooler lines. This info is missing from my 7A Bentley for some reason.
    1990 Audi Coupe - 7A for now
  • Mikes2
    • 1704
    the M6 bolts are 10 Nm or 7 ft lbs.
    The large bolt which holds the bracket to the block is 70 Nm
    Mike
    http://www.s2-audi.co.uk
