Is there any way of pressurising the system to check for boost leaks, or is it simply a task of following the air flow path checking all hose connections etc?
I've got a boost gauge on order, so obviously I'll check what mine boosts to first, but just wondered if there was any way of checking if the leak has been fixed without having to keep taking it for another run.
Ta
Ta
On some chipped cars, Overboost protection doesn't work(like mine),so you have no idea unless the leak is huge.
