This is a s6 aan ecu.Rew limiter is about 7500 rpm.This is not normal for a stock ecu.In an aan,ecu cips should be soldered,not with an adapter right?We don't know how much its boosting,how is the afr,NOTHING,because the car camed disansambled.I tried to put it on my urs4 but THE IMMOBILISER is in the ecu but my car is not equipped with one
I need a aan ecu with immobiliser pinout,maybe i can full ecu to run on my urs4.
How can i "lie" ecu that immo is ok?
Maybe someone knows or have an aan ecu pinout with immo so i would not need to dismember the immo ring from the a6 to see wiring and what's going on.
This is the ecu:
This is the ecu:
