Could be a blocked CAT alright... but check the throttle pot is doing its thing and that VAGCOM declares WOT when it should - the throttle opening determines how much boost you get. Should be seeing 1.5 to 1.6bar max on that setup, tailing off to 1.3 approx at redline.
Advice On Upgrades
[QUOTE=martinjs;486188]Did you get this sorted Paul?[/QUOTE
Just got it finally sorted this week mate the car developed another problem first though it started hesitating then started running on 4 cylinders so we fiited a new coil,spark plug and a POS which not only cured the missing cylinder but also the lack of boost
it's now running great and goes like a rocket
Great News M8...Just got it finally sorted this week mate the car developed another problem first though it started hesitating then started running on 4 cylinders so we fiited a new coil,spark plug and a POS which not only cured the missing cylinder but also the lack of boost
Will have to bring her down so you can take me out for a spin in it!!
Cheers mate I might pop down this week. Have you got an address for the bodyshop who did your golf please mate
cheers PaulComment
Went out for a spin in this today now it's cured and it's very impressive. It's now got 'Hoffer76' 390 spec chips in, boosted to 2bar in 4th, pulls like a train
1976 RD250E / 350LC cafe racerComment
Glad you liked it mate, thanks for your help in fixing it
looking forward to seeing yours when it's finished looks very impressive so far
How come you did not hear & feel it running on 4 pots only?Just got it finally sorted this week mate the car developed another problem first though it started hesitating then started running on 4 cylinders so we fiited a new coil,spark plug and a POS which not only cured the missing cylinder but also the lack of boost
it's now running great and goes like a rocketMarcel
________________________________________
current: RS2, + A2 TDI 3L
Favourit: Coupe Quattro Typ 85 or 859. I had one.
If you know someone in Switzerland selling a Ur-20V --> tell me.Comment
It wasn't doing this to start with mate, it was running on all 5 pots but not boosting past 1 bar the missing cylinder seemed to come on over night and luckily by curing that problem we solved the lack of boost aswelComment
