409.1 *should* run okay when you are logged in as Admin and running XP SP2 compatibility although it isn't officially supported by RossTech. I've also read reports that the XP compatibilty add-on doesn't fix all known ills from legacy software.
Attach the dump file for this fault and I'll take a quick look.
This is an unhandled exception error which could be caused by any number of reasons. You would need to configure a JIT debug*er to catch the exception and analyse the code in this region to hopefully find the problem or some clues at least.
Other alternatives to achieve compatibility are running a dual boot system with XP or running a VM of an XP install.
Nuvo - the log above is the exception from running in xp sp2 compatability mode as administrator, do you want me to install a JIT de******? Im downloading the windows 7 xp mode thing now to give that ago.
Sonic, VCDS 9081 *won't* run with your cable. VCDS requires the HEX-USB adapter which acts as a dongle. Your cable is a simple USB to serial converter and will only work with VAG-COM 409.1 and below.
Try the XP add-on pack first and see how you go with that. Wow! I didn't realise this "add-on" is a 500MB image file plus you need to install Virtual PC. I smell overkill.
The above unhandled exception details wasn't copied from a .dmp file was it?
Do a file search for this and sort by date and time to find the most recent fault log.
You would need to download and install WinDbg for this task.
Run VAG-COM and WinDbg should break, type !analyze -v into the command line and you will generate the exception analysis. Copy and paste this or attach it as a file if it is a particularly large body of text.
CommandLine: "C:\Ross-Tech\VAG-COM\VagCom.exe"
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the de****** choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
ModLoad: 00000000`00400000 00000000`00623000 image00000000`00400000
ModLoad: 00000000`77330000 00000000`774db000 ntdll.dll
ModLoad: 00000000`77510000 00000000`77690000 ntdll32.dll
ModLoad: 00000000`73bc0000 00000000`73bff000 C:\Windows\SYSTEM32\wow64.dll
ModLoad: 00000000`73b60000 00000000`73bbc000 C:\Windows\SYSTEM32\wow64win.dll
ModLoad: 00000000`73b50000 00000000`73b58000 C:\Windows\SYSTEM32\wow64cpu.dll
(de8.175c): Break instruction exception - code 80000003 (first chance)
*** ERROR: Symbol file could not be found. Defaulted to export symbols for ntdll.dll -
ntdll!CsrSetPriorityClass+0x40:
00000000`773e1220 cc int 3
0:000> !analyze -v
* Exception Analysis *
***** OS symbols are WRONG. Please fix symbols to do analysis.
*** Your de****** is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: ntdll!_PEB ***
*** ERROR: Module load completed but symbols could not be loaded for image00000000`00400000
*** ERROR: Symbol file could not be found. Defaulted to export symbols for C:\Windows\SYSTEM32\wow64cpu.dll -
*** ERROR: Symbol file could not be found. Defaulted to export symbols for C:\Windows\SYSTEM32\wow64win.dll -
*** ERROR: Symbol file could not be found. Defaulted to export symbols for C:\Windows\SYSTEM32\wow64.dll -
*** ERROR: Symbol file could not be found. Defaulted to export symbols for ntdll32.dll -
*** work. ***
*** Type referenced: IMAGE_NT_HEADERS32 ***
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the de******. *
* using .sympath and .sympath+ *
FAULTING_IP:
ntdll!CsrSetPriorityClass+40
ADDITIONAL_DEBUG_TEXT:
Use '!findthebuild' command to search for the target build information.
If the build information is available, run '!findthebuild -s ; .reload' to set symbol path and load symbols.
MODULE_NAME: ntdll
FAULTING_MODULE: 0000000077330000 ntdll
DEBUG_FLR_IMAGE_TIMESTAMP: 4a5be02b
ERROR_CODE: (NTSTATUS) 0x80000003 - {EXCEPTION} Breakpoint A breakpoint has been reached.
EXCEPTION_CODE: (HRESULT) 0x80000003 (2147483651) - One or more arguments are invalid
EXCEPTION_PARAMETER1: 0000000000000000
PRIMARY_PROBLEM_CLASS: WRONG_SYMBOLS
BUGCHECK_STR: APPLICATION_FAULT_WRONG_SYMBOLS
LAST_CONTROL_TRANSFER: from 000000007739183d to 00000000773e1220
