big power engines
  • pnanassy
    • Dec 2004
    • 287
    • Country: Hungary
    #31
    Which type of Motec do you have?
    Peter Nanassy
    Custom Engine Management,and Electronic Fuel Injection solutions supplier , contact me for details.
    http://www.carstyling.hu/car_shower.php?id=19845
    http://www.youtube.com/watch?v=FYOVA_285Rs
    • garym
      • Jun 2005
      • 106
      big power engines
      m800 with a add on box as we run fly by wire ,als, and launch ,and logging,10 injectors,
      • pnanassy
        • Dec 2004
        • 287
        • Country: Hungary
        #33
        cool setup
        that wont be the problem for sure,but everything depends on the tune.
        Peter Nanassy
        • ExPReSFin
          • Mar 2010
          • 3
          Here is a ++600hp engines on forum, what kind of valve timing you are using? Do you use cam manufacturers guideline timing, or your own timing(more overlap)?
          Audi Quattro 90, 508hp/580nm, more to come....
          • Audi_CQ
            • 940
            • Country: Norway
            #35
            Best cam timing can only be found on a dyno by trial and error I'm afraid. Start with manufacturers numbers and use small adjustments. Allways turn engine by hand to check for clearance after adjusting.
            • ExPReSFin
              • Mar 2010
              • 3
              I found few timings on the internet, all of those intake valve was more open than exhaust. Max intake valve opening was 1.2mm and max exhaust valve opening 0.9mm. That is pretty close to factory settings.
              • gnutz2
                • Aug 2006
                • 928
                Try putting some standard cams in it that should give it some bottom end punch.
                The ONLY S2 Golf!
                http://www.s2forum.com/forum/showthread.php?t=19402
                10.42@138mph
                https://m.youtube.com/watch?v=0wnkkOfFpXg
                • ExPReSFin
                  • Mar 2010
                  • 3
                  I have Holset MFS 67/70, so I think my bottom end punch is dead and gone
                  I'm happy if turbo kicks in about 4000rpm.
