more trouble ahead
  • shadquattro
    • 263
    • Home: England Current: Scotland
    more trouble ahead
    changed no 5 coil pack friday run it home was fine for five mins then started again took it back to my little fella and he checked all the wiring ,was under the bonnet for 2 hrs and now it looks like amplifier to plugs 4 and 5 is ****ed.
    this sound s like a fickin expensive nightmare,gonna hit the voddy after the race
    any one had this problem and how much of a **** was it to change.
    skint but fast
  • audiman
    • 4827
    doh!
    I cant help with this one, i bet the only ppl that can supply the amplifier is Audi, or VAGparts.
    Dont even know where abouts it is on the car as my 3B is totally different
    Tom C - www.rcmr.co.uk
    Audi UR Quattro
    Audi 100 C3 2.0 5 cyl 115ps
    Audi B5 RS4 645ps 911nm
      Madshad - one quick way to try a workaround on the cheap is to swap the cabling on the amplifier so that the dead channel is bypassed. Each amplifier has three channels - so the amplifier for 4&5 has a spare channel
      It requires some *CAREFUL* jiggery of the two connectors on the amplifier but a mechanic with the right tools to tweak AMP connectors like this should find it no trouble.
      Before doing this you might want to swap the amplifiers over, so that the problem should then move to cylinder #3 (IIRC). Please make sure your mechanic uses a heatsink compound on the back of the amps where they mount to the bulkhead. It can be got from Maplin and the likes for cheap.
      Paul
      • shadquattro
        • 263
        i have an amplifier coming from all audi ,the mechanic has already swapped the leads so that it moved to another coil, i will tell him about the compound when i see him 2morrow, am there so often they gonna get me some steelies and overalls
        skint but fast
