I was checking Pauls Timing belt renewal PDF yesterday for the crankshaft pulley bolt torque setting, when I noticed the washer / spacer that he points out in pictures 8 & 13.
I can't remember my 3B having one of these when I did the cambelt and neither of the spare pulleys I have has had one either. On the FA it is listed as ABY only but after taking a quick measurement of the end of the crank, there is a gap between the camblet pulley and the aux belts pulley of approx 3mm.
It's also mentioned here as for the ABY
Can any 3B owners confirm if they have the washer fitted?
