Just a quickie, been like this as long as i can remember but the engine fan does only run with the key in and the ignition on (without the car running).
Could this be interupted by the immobiliser
I am guessing this is not correct as if the fan is running and I take the key out it will not restart again.
Any ideas what to look at first? Afterun pump works as I can feel it vibrate slightly and also is pulsed when turning the car on.
Cheers,
David
Could this be interupted by the immobiliserI am guessing this is not correct as if the fan is running and I take the key out it will not restart again.
Cheers,
David
I'd have thought it would/should do because the temp would have been high enough to start the fan with the electrics on but if it ran for say 2 seconds and then i pulled the key out the temp wouldnt have dropped enough to not want to restart it...plus the fan cycle is like 20 seconds....if i flick the key again it would come back on.
I think it was due to the number of short journeys I was making in the car.
