So I've gotten some mixed review on what the stock pistons can handle. I know rods will do up to 400whp, but gonna replace those with some forged rods. I've been told that the stock pistons will handle 600whp. My ultimate goal with this motor is between 450-500whp. Should I replace the pistons, or will the stock ones do just fine?
AAN Stock Pistons
You'll need to drop compression using either stacked gaskets or an off the shelf thicker gasket to make 500whp otherwise you just can't run enough timing advance on stock pistons to get to that figure. The pistons will take it if they are the forged ones.
Depending on the year of production of your engine will dictate whether they are forged I5 pistons and or cast ones as used int he later years.
600whp I haven't personally seen anyone do I've seen 600flyhp which equates to a high 400whp so yes end target of 400-500whp is achievable providing they are the forged pistons.
hthUrS6 Stroker + HTA3586 =
RWD19T,
Mine is a 1993... Would this have the forged pistons in it? How would I know what pistons it has?
And yes, I will probably end up drilling the rivets out of the head gaskets and stacking them.
Rash,
I've heard the same thing. Thats why I'm wondering if I need to put new pistons in it when I do rods? The most I would want out of it is between 450-500awhpComment
The pistons themselves can handle the power, what you are talking about is can the engine at that compression ratio make power with the timing without detonating.
Two completely things that are being confused.
As said use a compression dropping gasket from 034 or skim the pistons taking CR down to 8.5 and the stock pistons setup will make your power.Comment
LWB Audi Sport Quattro projectComment
^^^^ iI couldn't be 100% but so far the only engines I have found the cast pistons in are late 1995/96 AAN engines in the UK. Where they have are a considerable weight difference of around 10 grams and a different manufacturers stamp on the underside. Yet they all have the same part number from Audi go figure
Not wishing to discount what you have found and indeed measured but are you sure these other pistons are not also forged?^^^^ iI couldn't be 100% but so far the only engines I have found the cast pistons in are late 1995/96 AAN engines in the UK. Where they have are a considerable weight difference of around 10 grams and a different manufacturers stamp on the underside. Yet they all have the same part number from Audi go figure
I would guess that there were two OE suppliers, KS and Mahle. It would not make any economic sense to tool up again to produce inferior cast pistons for a limited and short production run.
I have seen pics of both and I seem to remember that the Mahle ones has simplified valve relief cutouts than the KS and differences to how the bowl was machined. Whether that accounts for the 10g difference or not I don't know!
I have only seen KS ones in stock engines although its possible that Mahle was used towards the end of the production run if the ones you have seen are stock sized.
There are bound to be pics on here somewhere of both types of piston!Comment
Zero problems pushing out 500+ hp on stock pistons ! I had 620 Whp stock pistonsComment
Its a reason the lemans race diesel cars have the MAHLE logo in the front
Keep pushing eh.
No need to buy expensive forged pistons when u allready have it mate.Comment
and do you know how long could be the original pistons life with more than 500hp??
or they are for ever if the engine work always perfect ?? piston rings will have to be replaced and upgraded true??RED Mitsubishi Lancer Evolution VI TME nº 16 of 250
Ofcourse the rings should be replaced and polished to correct measures.
We got guys over here pushing over 650 easy on stock pistons.
Its good ****, only disadvantage is the valve pockets in stock pistons. ur not able to have high lift on cams. my last cam adjustment with 7A cams 2,2mm Intake cam 1.6 Exhaust cam from this setup u will get nice respons and fast spool up
Good luck eh.
JComment
and did you skimed them for get lower compression ratio??
9´3:1 it is the original CR...so how many distance to skim for 8´5:1CR with the same 144 rods and original metal head gasket??
