How is the URS4 coolant system bled?
  • s2_bo
    • Oct 2005
    • 6067
    My S4 seams to stay at one notch above 50c on the temp gauge all the time so i think the thermostat is shot as its not getting up to tempreture. I will replace it soon but was wondering how you go about bleeding the coolant system afterwards? There is no bleed screw on the rad as far as i can tell?
    91 S2 coupé - RIP
    98 S8 - Luxury barge
  • JP
    • 1858
    Look under the cover of the scuttle panel. Find the coolant hose to the heater matrix and on the top of it will be a bleed screw.
    HTH
    UrS6 Stroker + HTA3586 =
      Sometimes, it's not the thermostat at all, just a bad signal from the MFTS which drives the temp gauge. You might want to do a diagnostic using the climate control head (if you have the automatic climate control) as per this Thermostat DIY post:
      Or have a look at this MFTS post:
      Personally, I have replaced my thermostat and never worried about bleeding the system, just get the thermostat oriented as show in the diagram in the first post and turn up the heater to get water flowing through the heater core.
      • s2_bo
        • Oct 2005
        • 6067
        Thanks guys!
        I dont have climate control so will try a new mfts as thats quicker then changing the thermostat.
        91 S2 coupé - RIP
        • merlin's S4
          • Jan 2005
          • 1539
          Thermostat isn't too bad to replace on the S4 if you've got some knuckle socket extensions. Just remove the intake hose to the inlet manifold.
