coil pack question
  • vonbeck
    • 2455
    coil pack question
    went to change plugs over weekend lifted the cover off, and while checking the rubber boots came across this do you think i need to change the coil pack as the boot covers the missing piece,car went into dealers about 12 months ago for little job so i`m guessing it was done then but can`t prove it as i`ve been changing the plugs myself for ages,and if so are thecoil packs easy to change and are they dealer only parts cheers in advance
  • pixsaudisex2
    • Sep 2004
    • 3110
    Number 5 is the best one to change,, you can do that one on its own. try quattro corner for one. but if it broke an its still working do you fix it tough one that.
    • vonbeck
      • 2455
      it is number 5 and as far as i`m aware its still ok no missfire problems i will price one up and see how much they are
        They are 70-90 quid each... Easy enough changed if you are tidy with splicing in new wires or making up fresh connectors.
        If its not misfiring then leave well enough alone - the HT boot is doing its job of keeping spark en route to the plug by the sounds of things.
        • Fat Audi 80
          • 10547
          Would that be the grease monkeys not taking the cover off carefully and levering it up?
          The Perfectionist
          • mallster
            • Jan 2010
            • 81
            Having bother with no 5 myself mate if it aint givin you any grief leave well alone mate what a ballache!
            • pixsaudisex2
              • Sep 2004
              • 3110
              Not taking the throttle return thingy of causes this..
              • Fat Audi 80
                • 10547
                Do people NOT take it off then.
                The Perfectionist
                • vonbeck
                  • 2455
                  i would think so i take the thottle thingy off its only 3 bolts
