I've been looking around but it doesn't seem like there is a gasket for the wastegate between the exhaust manifold and the wastegate? I wanted to use one as a template for machining a flange for one.
Is there a gasket between the wastegate and exhaust manifold?
I chose not to choose life: I chose something else. And the reasons? There are no reasons. Who need reasons when you've got quattro?Tags: None -
Ok Sounds good.
Thanks for the reply.I chose not to choose life: I chose something else. And the reasons? There are no reasons. Who need reasons when you've got quattro?Comment
I might snag one of these off of ebay. I think I might be able to get it to work:
Crap nevermind on this setup. Someone on ebay posted that the 944 turbo wastegate is the same as the audi stuff but it's actually quite a bit different after a little more searching.Last edited by Josh-stateside; 14 March 2010, 02:24.I chose not to choose life: I chose something else. And the reasons? There are no reasons. Who need reasons when you've got quattro?Comment
