4.0 bar fpr
  • rs200
    • May 2009
    • 1398
    • Home: Croatia
    4.0 bar fpr
    hello people..
    i have one question about FPR... well I put AAN ecu in audi 200 20v, and I need 4.0 bar FPR...
    well the original FPR (AAN) part number is 078 133 534 C
    I find from 2.8 V6 - 078 133 534 A
    both FPR is 4.0 bar.
    can I use this second fpr like alternative?
    is there any difference between these FPR's ???
    thanks for help
    I find from 2.8 V6 - 078 133 534 A both FPR is 4.0 bar. can I use this second fpr like alternative? is there any difference between these FPR's ??? thanks for help
    Actually the A is the original and the C is the replacement UrS4/S6 FPR. There are some signs that the A is better than the C, as shown here:
    • da_trem
      • Mar 2008
      • 45
      What would be the difference between the 2 at wot? Would the "C" make restriction in flow at the return line causing the motor to run richer?
      1996 Audi S6, VEMS, S362.
      • rs200
        • May 2009
        • 1398
        • Home: Croatia
        well URS4boy sad that A is original.. before 20min i put it on my car and it work perfect.
        how I know?
        because on air/fuel ratio gauge I saw it is always in optimal mixture.
        before with 3.0 bar (3b) it was sometimes in optimal but much time in lean mixture.
        I think now is super because on 1.4 bar boost it's still in optimal ...
        thanks every one for help.
