How to spot 1 (or more) out of 20 cam followers faulty?
  • Martynf
    • 1885
    Now I am a bit baffled.....
    I KNOW I have 'some' failing camshaft followers, but I can't tell which ones are lame?? it aint that obvious!!
    Car from cold is nice n quiet, drive her for 10-15 minutes and my lord, it sounds terrible!! I'm embarrassed to drive her!!
    I've got her stripped right now, if I turn the crank by hand so the cam lobes are vertical, then using a blunt rigid plastic probe I try to push down on each follower in turn, I cannot spot any 'lame' followers!! every follower feels solid to me!! I cannot push any of the 20 followers down, not by one 0.0001 mm!! they are all solid.
    I'm sure I dont HAVE to remove the cams to check the followers (as with the lobes vertical they don't touch the followers) , but it looks like I will have too to be completely sure..
    Anyone any comments?
    Removing the cams and having to reset everything afterwards is not something I want to do unless I have to!!
    Ideas?? any BTDT's??
    Cheers!
    Martyn
    www.vagparts.com
  • Mark Halligan
    • 2001
    Cheers!
    Martyn, yep I changed all twenty of them .
    Sorry mate, I couldn't resist that .
    Cheers,
    Mark.
    Mark - Modded
    • sal_s2
      • 1287
      Cheers,
      Mark.
      So did I
      • Martynf
        • 1885
        Why thanks guys, I knew I could depend on your professional opinions
        Martyn
        www.vagparts.com
        • Beetie
          • Oct 2003
          • 1517
          To be honest as a mechie and all that, i'd change all 20 as well, just to be on the safe side, and make sure the jobs done proper....
          Im sure u can afford all 20 now ive got my credit card out....
          • audiman
            • 4827
            Just change all 20 you tight git. If you gonna do a job, make sure you do it the right way!!!
            Tom C - www.rcmr.co.uk
            Audi UR Quattro
            Audi 100 C3 2.0 5 cyl 115ps
            Audi B5 RS4 645ps 911nm
            • Beetie
              • Oct 2003
              • 1517
              Aint that true!
              • Graham
                • 1622
                I changed all 20 even though 2 were giving me problems, its the expensive way i know but it saves pulling her apart again in 3 weeks time when another one decides to go on a wobbler.
                Graham
                • Vagsport
                  • 533
                  Change ALL 20 of them AND put the old ones in the bin! That way you don't get tempted to used them again
                  Siena
                  • Doug_RS2
                    • 3847
                    I never changed mine and it doesn't tick. It did tick with the oil level a bit low and after a thrash - I just keep the oil on the top level and use a decent thick oil - maybe you should try something differnet to the synta silver Martyn?
                    • audiman
                      • 4827
                      Im not gonna be changing mine, they do also tick after trackdays etc and after a good rant.
                      Audi UR Quattro
                        Martyn - I would try her with Castrol-R 10w/60 then see how that sounds. Perhaps a quick dose of engine flush before hand will help rid old oil, but I understand your concerns if you don't believe in engine flush.
                        Gotta agree with the conventional wisdom on changing them though - all or nuthin'
                        Paul
                        • Martynf
                          • 1885
                          shoot, the funds for the mods are getting smaller by the second
                          Martyn
                          www.vagparts.com
