Bosch 044 motorsport pump max power output
  • QuattroFever
    • May 2006
    • 1360
    i remember reading a thread a while ago and there was an 044 with a diff. Part no. Think it had a B at the beginning and was a 10bar version. Couldnt track dowm the thread tho.
    Volcano ABY coupe
    Ant
    • EspenW
      • Apr 2007
      • 1534
      • Country: Norway
      I think I'm right at the borderline for the output of a single 044 on ethanol with a little over 400whp, so around 500 at the crank.
      On E75 winter fuel (75% ethanol), the AFR stays where I want it with base fuel pressure set at approx 3.6 bar.
      Max boost pressure is 2.1 bar.
      On E85 however, I can not get the AFR down to target no matter how high I crank the fuel pressure.
      E85 requires 30-40% more fuel for the same lambda, compared to petrol, so the limit is quite high.
      Fuel lines are stock size, however, the pump is fed with 14.5v, (15.3v at alternator and pump is fed via relay and fat gauge wire) so that raises the output of the pump.
      1994 80E Avant
      1986 2L Golf 2 on Alcohol
      • Rocco
        • Aug 2007
        • 6393
        • Country: Spain
        and then are you still convidced that there are 2 kind of 044 pumps with 5 and 10bar??
          He is correct although they are the same pump techically.
          Bosch test the output of the pumps and ones that can support 10 bar are marked as motorsport else they are marked the normal 5 bar pump
          • Rocco
            • Aug 2007
            • 6393
            • Country: Spain
            #20
            so...all are the same pumps true?? all are called 044 Motorsport pump....
            part numbers 0 580 254 044 ....
            • Doug_RS2
              • 3847
              #21
              650bhp fw is the safe limit of a 10 bar pump on stock lines - that is with the one way valve removed.
              The 10 bar rally spec pumps are the pick of the bunch and will flow the same rate at 10bar as a 044 will at 5 bar. You also get one rated at 8 bar.
                Where's the one way valve located Doug?
                • repo
                  • Dec 2004
                  • 893
                  Screwed directly on the pump outlet.
                  • Rocco
                    • Aug 2007
                    • 6393
                    • Country: Spain
                    #24
                    http://cgi.ebay.de/BOSCH-044-MOTORSP...item2ea196955c
                    this seems to be the 10bar pump , 267€
                    http://cgi.ebay.de/Bosch-Motorsport-...item3ef2aff013
                    and this one the 5 bar pump.. ? = 189€ , cheaper than the other one from ultimot.de
                    http://cgi.ebay.de/RS-Cosworth-Bosch...item23061a69a6
                    and finally this one too....from UK ebay...far cheaper than the 10bar pump from ultimot...
                    i think that it is the same pump but selled for Ford cosworth owners
                    you guys...what do you think about them? i would bet for all the 3 pumps are 100% the same
                    • Tommy200rs
                      • 285
                      #25
                      OT:
                      These could also be an alternative:
                      http://aeromotiveinc.com/products-page/fuel-pumps/ And there last row/next page. Most (HIGH volume) high pressure pumps need a low pressure delivery pump that there always is plenty of pre-delivery for the high pressure pump(s). Check also the fuel temp in case of problems. Heated fuel is bad for power "economy".
                      • a4kquattro
                        • Feb 2005
                        • 411
                        Originally posted by Tommy200rs
                        OT:
                        I've had extremely bad luck with the Aeromotive pumps on Ethanol. Ok for gasoline, but STAY AWAY if you ever intend on running E85.
                        Marc Swanson
                        Proprietor, EFI Express
                        95.5 //S6 Avant
                        90' Coupe Quattro V8 4.2L twin turbo
                        93' //S4
                        83' UrQ
                        97' F250 7.3 diesel
