Bl**dy starter again...
  • salmon
    • May 2004
    • 134
    Starter motor jammed again, and this time the trusty technique of ****ting it with a hammer won't work .
    So task for tomorrow is to locate a new starter, anyone any idea if it is a specific S2 part, or common to other cars?
  • Jas11n
    • 5067
    Looking at the part numbers for your 91 3B it lists the part number as being the same on all 5 cylinder engines, 034 911 023 X, for engines KV, NG, NM, 7A, 3B and ABY. Only the six cylinder lumps seem to have a different part number (AAH and ABC).
    If this is correct, then there is one on eBay at the minute eBay link or alternatively there should be one in the millions of scrappies around Newcastle.
    If I'm wrong then I'm sure one of the parts guru's will shoot me down
    2001 Avus Silver B5 RS4.
    1995 S2 Coupe - sold (sniff)
    • salmon
      • May 2004
      • 134
      Thats just what I wanted to hear, cheers.
      Think I'll try and visit a few scrappys tomorrow, then I'll get the fun task of putting it back on, was a right swine to get off!!
      • Jas11n
        • 5067
        Even better if you've already got it off, then you can take it with you to compare..
        • salmon
          • May 2004
          • 134
          very true!
          • salmon
            • May 2004
            • 134
            Out of interest, is this the same for the 5 speed gearbox, or is this a specific part?
            • Jas11n
              • 5067
              I think this has been recently talked about, thread link below
              3b 5 speed box
              • salmon
                • May 2004
                • 134
                Cheers for the link
                • porkkis
                  • 1994
                  Any 5cyl audi starter should fit. So second hand ones should be really easy to find (A100, A90 etc). If you end up buying a new original one, note that X in P/N means it's an exhange part.
