Timing belt change- parts lists
  • Harvey
    • Jan 2010
    • 62
    Before putting the ABY into the ur I plan to make as many sensible changes as possible.
    Next up is the timing belt. What would be a sensible amount of stuff to replace when down there? I anticipate the following:
    belt, aduster, idler roller, water pump, crank pulley and fasteners, crank pulley bolt, front crank oil seal?
    Is it worth changing the oil pump given that I don't know the mileage of the engine but it is certainly not 'done' judging by the amount of wear and maintenance I have ascertained. A deciding factor on the oil pump might be price. What do they cost new from any sources that supply them? I paid £180 for the one from Audi I replaced on the WR engine when I rebuilt it, is that typically or is replacing the oil pump really necessary?
    Anything else i have forgot? Many TIA for any suggestions
    quattro non solem quattro
  • add
    • Jan 2008
    • 931
    That sounds about right for the belt change
    The crank sprocket is a MUST,i know from first hand experience.
    Make sure the crank bolt is tightened correctly.
    you could always remove and strip/check the oil pump before you buy another,if it's in good condition why replace it.
    It's a love/hate relationship with the S2,i love it,it hates me
    • Flat on my back
      • Jan 2007
      • 2449
      Have a good read...
      Carlos.
