My S2 is dead
  • s2_wot
    • Aug 2006
    • 2178
    Alternator?
    Jamo, I think your alternator could be knackered. My s2 stopped exactly as described above and with the alternator reconditioned it didn't do the same again. Reading your other thread I think it would be worth a bench test to eliminate it.
    HTH, Shane
    Shane
    • madpugger
      • Sep 2007
      • 1901
      I would suspect power to the injectors in that the ECU is putting out the pulse but the injectors are not pulsing.
      As said you have a spark, so the hall sender must be fine. Also, that wouldn't have cut it out while driving. As it is all the injectors i would think it is a common power that has gone, either a fuse blown or corrosion around the fuse blade etc.
      Le Mans 2012
      Nurburgring 700
      1995 S2 Avant
      • s2carlo
        • 252
        Hi Jamo,
        hope you don't have the same thing I had.
        Mine also just cut out and wasn't restartable although everything was available.
        Turned out the spline on one of the pullys broke out and immediatly got stuck again.
        Causing the timing to be slightly of.
        No power, no glory!
        S4 Avant, 2003, K&N-filter, 18", RNS-E, enough audio
        • s2avant
          • 2426
          Injector fuse would be my starting point. Especially after my recent similar problem with the V8. RAC did all the tests they did on your and it turned out the fuse was hanging out of the fuse holder. It was in just enough to make contact but when it fired the fuse moved and it cut out again. It makes a pretty effective immobiliser for when it's parked in the less desirable parts of town.
          Ben
          • GazzaG60
            • 4133
            jamo.
            whem on motronic i never had a can sensor issue.
            my first fail. gunning up a hill went for 5th and it felt like a wobble so lifted off. tried to start it again. only just started and died. fail cam sensor 1. original part
            second time. cruisnig same hill after a quick smoking of a 2.7tdi A5. i short shifted lol. and it did the same. tried everything. changed the cam sensor again. endfed up being a snapped cam between lobes on 7a ex cam cyl4. miricle of no engine damage.
            does it start, try to start, start and stumble. is it fueling, sparking.
            id take a look at the 2nd vr crank polarity switch too.
              As there is no pulsewidth to the injectors it doesn't try to start just turns over. I
              'm wondering if my new injectors draw more current than the old ones.
              My battery is flat so now have to charge it up before can progress. Will check injector fuse at lunch time
              • AndyP
                • 6049
                You had me worried when I saw the thread title, I thought you'd crashed it
                Anyway, you've said that you've being having problems with the battery charging recently, does the VEMS ECU have any sort of undervoltage protection, i.e. it will shut down or not work properly if the supply voltage drops below a certain point?
                  It expects 12 volts to it and I know from reading the VEMS wiki strange things happen under 11 volts.
                  The RAC man had his jump leads connected up to the car so I was seeing 13v with the ignition off during cranking. I've found an injector test routine in VEMSTUNE which allows you to turn on or off the individual injectors.
                  I had an expected phone call from Finland with Repo offering some great advice, most unexpected and appreciated
                  Thanks all, I've got a few things to try and I'll post back up once I've had a chance to looked them over
                    Gold stars for Terrybullwon, A4kQuattro & S2avant the issue was caused by a blown 15 amp fuse in holder 28
                    Worth noting in future that this fuse is for the injectors, it's the right hand fuse of the two fuses covered with the red motor cap.
                    Any suggestions as to why this blow? was only doing 30 mph on cruise when it happened?
                    • S2 Ant
                      • 3682
                      Glad you found the issue mate, i thought the same as Andy and was expecting to see a mangled car!
                      Fuse blowing could be a number of things - do they require more power than the original injectors? If not then possibly a short somewhere? These would most likely show themselves again if you replace it and it goes not long after. A break in the wire might earth out over a bump or something perhaps.
                      Replace it and keep a spare handy and see how it goes i guess - at least its nothing serious after all the work!!!
                      Ant
                      2011 Kawasaki Z1000
                        I'm wondering if it's in relation to the audspeed controller I removed..
                        I have a couple of batch of fuse boxes in the car, when I originally bought it it had a different set of HID's on the car which kept blowing the fuses so I stuck them on my old Coupe and they worked fine, way of the world
                        • GazzaG60
                          • 4133
                          good to hear jamo
                          • PeteUr
                            • Jan 2010
                            • 331
                            • Country: Togo
                            #28
                            Glad you got it sorted mate
                            Sapphire cos running custom 2.8litre conversion,es cos rims,raven black leather interior and 500+ with the gas turned off.
                            Audi s2 cooking on gas
                              Thanks for all the advice folks, easiest fix I've done in years
