3b fan owners...
  • s2driveruk
    • 12696
    3b fan owners...
    Trying to work out if mine is dead whilst its out of the car or not.....when i turn it by hand it feel like the second hand on a clock - what i mean is rather than a smooth turning motion it kinda turns with a motion like the second hand on a clock - is this right of does it indicate the end of its life. Am wondering if this is the problem why its probably drawing so much current on start up and causing the terminals on the connector to show heat damage.
    Thoughts please before i go and reinstall it. With the summer journey it has planned, i need and want every aspect of the cooling circuit 100%
    1992 3b S2 Coupe
  • Evilgoat76
    • Feb 2010
    • 278
    • Home: Canada Current: United Kingdom
    Its called 'cogging' many high power electric motors like this do it. Its possible the motor is developing an internal fault such as shorted windings etc. I'd sat bring it down the shop but thats a beast of a motor on that thing and all I'd be able to do is meter it and compare against my ABY one. You are welcome to pop it over though.
    • s2driveruk
      • 12696
      wouldnt mind a check over by someone who actually knows what to look for where abouts are you?
      1992 3b S2 Coupe
      • Evilgoat76
        • Feb 2010
        • 278
        Havant Road in Drayton, just off the A3. Addy is at www.realitytech.info
        You are of course welcome. For a PC shop I have a large amount of broken bits of car in here
        • s2driveruk
          • 12696
          any day this week a better one as I am off all week pretty much
          1992 3b S2 Coupe
          • Evilgoat76
            • Feb 2010
            • 278
            open mon-fri 10 till 7, closed wed, sat 5-9. Have to open up late tomorrow due to having to take the dog to the vet (to be shaved....I wish)
            • s2driveruk
              • 12696
              cheers - migt pop over tomorrow at some point, will pm my details...
              David
              1992 3b S2 Coupe
                You can get the ABY / ADU ones off Bosch for reasonable money if it is dying mate
                  I'm still looking at getting alloy rads with fans sorted out at some point as a solution to the 3B behemoth
                  • s2driveruk
                    • 12696
                    How simple is the swap - i guess you need the resistor pack etc right?
                    1992 3b S2 Coupe
                    • s2driveruk
                      • 12696
                      Thanks to Ric - nice to meet you btw I think we can assume the fan is fubar'd. I'm off on the hunt for something suitable unless anyone has any suggestions. Looking for minimal additional leccy work as I am a numpty when it comes to this stuff plug and play has got to be the best solution or i am stuffed i think
                      David
                      1992 3b S2 Coupe
                      • Evilgoat76
                        • Feb 2010
                        • 278
                        Thanks dude. As I sasid, really want happy about the state of that fan but did think after you left that it may be worth going as far back into that loom as you can get and replacing the wiring. ABY Has two fan fuses, there is a resistor somewhere and a relay too I think.
                        Wiring for what you have is here
                        Now confused about that ally affair on the top of the condensor. Robs ABY Avant has the same as yours and the manual I have says thats the standar setup for the AC and nothing is in that third position. God knows where the setup on mine came from :S or what that missing sensor is.
                        • s2driveruk
                          • 12696
                          hmm, so been making some enquiries with Bosch and basically the fan motor was discontinued with no supercession in June 2006.
                          For reference the Bosch part number is 0.130.109.238 DPE 12V Axial
                          The nearest match (though not direct) is 0.130.109.207 DPE 12V Axial - awaiting availability and prices currently but apparently was a direct fit on an Audi 5000 2.2!
                          The details are here:
                          I'm in contact with Bosch suggested specialist: Ellis Components - 01773 873151
                          If you want to contact Bosch UK - 01895 878197
                          David
                          1992 3b S2 Coupe
