Turbo bracing
  • dest
    • 4287
    • GazzaG60
      • 4133
      my original wagner had wastegate issues not turbo. think the gate needs a brace idealy too.
      i have had no issues wit the 1 brace.
      the weight of the turbo on the tubes is a long way from pivot point so to speak enhancing its weight if you get my drift. as you fit the brace you can feel the tension removed from the tubes and the turbo lifts a little too.
      its a must on tubes. cast, well they sit so close to the engine you cant really get a big turbo in there. then theres the flow.
      • Puglife
        • Jun 2006
        • 731
        The important section os bracing is the triangulation between rocker cover and manifold...
        Rosejointed bracer will allow tension to be set nicely which will remove a fair bit of the strain on the manifold.
        Jay - pug_life85@hotmail.com
        1986 Audi UR quattro - WORK IN PROGRESS
        1981 VW Mk1 Golf - "20v Jim, but not as we know it!"
        • gnutz2
          • Aug 2006
          • 928
          I used 10mm round bar with a male and female rosejoint from rally design on the end.
          I welded a tab onto the bolt washers that hold the turbo together.
          The ONLY S2 Golf!
          10.42@138mph
          • QuattroFever
            • May 2006
            • 1360
            i i
            i i
            i i
            as above
            my pic. was better
            Volcano ABY coupe
            Ant
            • quattro84
              • Mar 2006
              • 947
              The newer OEM mounted holsets on trucks are supported by a piece of spring steel strip from underneath against the engine block...
              • terrybullwon
                • Mar 2006
                • 8782
                Cheers Baz, thats a great one!
                This is pretty epic
                Chef
                • gnutz2
                  • Aug 2006
                  • 928
                  Awsome, that must be an old formula 1 reno v6
                  The ONLY S2 Golf!
                  10.42@138mph
