I hope someone can help me!!
I have a 1995 S6 avant (AAN) with a very long standing and very annoying running fault!
As the car reaches 2800 rmp ish the turbo starts to do its job as normal, but then as soon as full boost is reahed, roughly 100-200 rpm later the car surges horribly right through the revs, its awfull!! Although i rigged up a mechanical boost gague and the boost figures are rock steady and spot on!
However if i get to about 4000 rpm on light throttle then stamp on the throttle it pulls very well.
I have another S6 which works well and The parts i have changed car to car or for new for this fault and others are as follows: (and nothing has made even a slight difference!!)
ECU
Coil pack complete
POS units
Cam position sensor
Both crank sensors
Turbo
Cats
Valve stem seals
Check valve timing
N75 valve
Knock sensors (both)
MAF sensor
Plugs
Air Temp sensor
Checked breathers are clear
Visually checked all boost hoses
Cheked throttle sensor values
Lambda sensor
I'm at the end of my patience as i love the car but as it is, it is useless as a fast car as the turbo can barely be felt coming in dispite what the gague says!
Has anyone had/heard of this before??
ECU
Coil pack complete
POS units
Cam position sensor
Both crank sensors
Turbo
Cats
Valve stem seals
Check valve timing
N75 valve
MAF sensor
Plugs
Air Temp sensor
Lambda sensor
