SQ EM and K26 Turbine
  • Billman
    • 4129
    Hi,
    what are the differences and is it easy to mate a SQ exhaust manifold with a k26 housing? Don't ask why!
    Go Holset or Go RS4
  • aronmatic2
    • 2129
    • Country: Hungary
    Originally posted by Billman
    Hi,
    easy. 15 minutes.
    Real carbon parts for S2 and RS2. Check Carbondesign on facebook
    • Billman
      • 4129
      nice....some pics or details? do the bolt holes align?
      Go Holset or Go RS4
      • aronmatic2
        • 2129
        • Country: Hungary
        i try to find some pics, but if you hold the 2 pieces in your hand, its will be clear.
        you have to modify the bolt holes on the housing.
        • Billman
          • 4129
          a, ok that easy. If there is enough space then its ok! Do i need a spacer plate? Is there this ring that protrudes like in the RS2 manifold?
          Go Holset or Go RS4
          • aronmatic2
            • 2129
            • Country: Hungary
            no spacer. you will need a larger gasket.
