S6 WOT fault
  • Knight Rider S4
    • 3541
    S6 WOT fault
    I am looking at a friends UrS6 for him to see if I can sort this wierd issue out
    Current faults:
    The car has a lumpy tick over 760/800 up and down abit
    When accelerating WOT it feels retarded in some way and judders at 3500 /4000rpm
    Boost gauge is showing 2.0bar(so 1 bar all in )
    Things I have done to try a fix problem
    Scanned with VAG.com no codes, did full output test and all it working as it should
    Checked VAC lines going to ECU and moisture trap all good (1008Mb)
    Swapped over MAF no change
    Swapped over POS's no change
    Checked Coils and they look like they have been changed not long ago ..look new as is the wiring...boots are tired looking and have been wrapped with insulting tape (possible cause)
    Did visual check of boost hoses and check clamps to make sure they are tight
    The car has been in a garage before it came to me so double checking every they have done ..fitted new speed sensor
    So anymore ideas to add to the mix were I should look or test ..plug boots is a high contender ....Would like to test the coils just to make sure one is not fail under load ,The car has this issue with idling as well which makes me think it is something else ..like it is drawing in unmetered air
    Steve
    93 S2 Avant Parting
    91 URQ RR
    02 A4 tdi Avant
    I am guessing that there is an air leak somewhere or the O2 sensor needs replacement to solve the idling problem. For the WOT missing, that is usually coils but you should start by checking/replacing the spark plugs and the coil to plug boots. If you haven't already done so, have a read through this (and its internal hyperlinks):
      There are also a few more things that you could investigate in this ENGINE BAY DEVICE MAP.
      • Knight Rider S4
        • 3541
        Cheers Dave ...forgot to mention plugs have been changed so has the fuel filter ..will scan through link and see if it brings up anything I have missed
        93 S2 Avant Parting
        91 URQ RR
        02 A4 tdi Avant
        • HMS-S6
          • Jan 2010
          • 1164
          I feel for you, sounds you and i have a very similar problem!!!!
