There are many more viaribles to consider. Injectors are not so much a deciding factor either, as long as they are large enough and have a decent pressure and spray patten they will all preform pretty much the same.
Plenty of info already available on the forum if you do a quick search
Look at projects of Ross, Bram there's a few more but can't think right now for 3071 engine setup with those specs, Aronmatic2 for the 3076r setup before he went stroker
Things like this aren't absolute as no 2 engines are the same and neither are the setup.
The injectors make no difference to bhp output if they are sized correctly, more about the smoothness of the engine.
You should be more focusing on what your bhp target is and then deciding the best turbo to hit your target or you'll end up confused about the way to do it.
There is no wrong and right way can be achieved in multiple ways, pick you target and build around it
it not just bhp im looking for i would rather have more torque than high end power at
6-7000 rpm and would like a rough idea at when these turbos kick in i know there is many factors
thanks
