oil line for garrett turbos
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    can someone with a pachymeter whether the oil line feed to the garrett turbos usualy sold by 034 is an -8AN size?
    OD:0.65mm
    i have the line and need to buy some aeroquip fittings to modify the length.
    on one side of the line it says -4 but it seems to thick to be -4AN (.22/.44mm)
    thanks
    vasilis
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    edit,
    my mistake as the .22/.44 is in inches so its the -4AN
    anyone knows if the locking aeroquip fittings are able to sustain the 5bar of pressure? or should the oil line fitting be definitely fixed?
