cam belt snapped
    Might you have mixed up some electrical plugs when doing the head work ?
    Check you are getting pulses from hall sensor at the distributor (5V LED on the middle pin wrt 0V should see pulses every 2nd crank rotation) and of course check twice that the mechanical alignment of crank, camshafts and distributor is as it should be
    • Polish
      • Feb 2008
      • 126
      as far as i can see i only disconected about 4 plugs they are all back on there is no power to th hall sensor(plug on the side of the dizzy? there was earler but not now? im confussed and it dont take much
      • 90/90qs
        • Jun 2006
        • 244
        you have you timing marks aligned on the wrong stroke?
        http://s260.photobucket.com/albums/ii11/minipitt1/
        • Polish
          • Feb 2008
          • 126
          yes have double checked but i should still have a spark?
          • GazzaG60
            • 4133
            earths corner of rocker cover. is it good.
            • Polish
              • Feb 2008
              • 126
              can only see earths on the inlet manifold dont recall undoing any earths
                #22
                With ignition on you should see steady +5V across the outer two pins at the hall sensor plug. If you don't have that, the engine will never start.
                Have a check that all the fuses are good just in case.
                • Polish
                  • Feb 2008
                  • 126
                  Have checked the plug i have feed to one side think black & Red which fuse? thanks for your help as ots doing my head in now
                    #24
                    Check all the 3B engine fuses here - http://www.s2central.net/motronic_04_fuses_3B.html
                    • Polish
                      • Feb 2008
                      • 126
                      will have another look tommorrw fingers crossed and a fresh and clear head
