hi guys not been on 4 a while.Ineed a little help a while ago I removed my 3b head & renewed head gasket long story short i have a plug spare doh!!!the engine wont start.messed it up proper me thinks.would like to know if this plug is y.the plug is a 2wire connection at the back to right as you look at it.1 wire is brown/blue stripe other brown/white stripe.the middle of the plug is purple.where the blazes does it go?????????cheers for help guys in advance.
unplugged??
Tags: None
TBH cant bloomin see.looks like i have to strip out again.really don't want to with my luck.hoped someone would say defo blah blah an i'd be back in the runningI must have an S2!!!!Comment
If it was the distributor plug, you would be able to see.
Let me see if I can find any references in the schematics.If at first you don't succeed, destroy all evidence that you tried.
-CQ 3b "S2".Comment
I'd suggest pulling the codes for the non-start. It may give a clue.
You can have a look through the wiring diagrams here
I've not seen a brown/white and brown/blue combination listedMike
http://www.s2-audi.co.ukComment
I can say without looking at the schematics that the declared wire colours on that 2-pin plug must be wrong as the sense of a brown wire is permanent earth whilst brown/anything is a switched earth and is such would be weird to have two switched earths going thru same 2-pin plug.
I will look at my 3B pages and see if anything looks like a candidate for a no-start but have another look at the wire colours and check you haven't mixed up G4 & G28 on the flywheel. Also a missing G40 would cause no start.Paul Nugent
paul,so sorry mate this car is a cq 20v with a 3b in the wire colours are correct but they look like the car loom.sorry again.any ideas??p.sthose numbers mean nothin to a peasant such as myself :-(I can say without looking at the schematics that the declared wire colours on that 2-pin plug must be wrong as the sense of a brown wire is permanent earth whilst brown/anything is a switched earth and is such would be weird to have two switched earths going thru same 2-pin plug.
I will look at my 3B pages and see if anything looks like a candidate for a no-start but have another look at the wire colours and check you haven't mixed up G4 & G28 on the flywheel. Also a missing G40 would cause no start.I must have an S2!!!!Comment
Can you post a photo of where this mysterious plug is ?
I like a challenge :-)Paul Nugent
these are the photos as promised. challenge completed.
Having just taken my (ABY) head off a couple weeks ago, I seem to remember there are two plugs below the throttle body somewhere that are pretty close to being one on top of each other. I am not home to go have a look though sorry.Comment
