Helicoil Spark Plug
  • Tonks4x4
    • Nov 2005
    • 3062
    Helicoil Spark Plug
    Had to perform keyhole surgery today on a 20vt ABY.
    It had suffered the loose spark plug syndrome and then ate away all the threads...
    I must admit I was not looking forward to doing the job, but turned out to be, not a bad task at all. I purchased a V-Coil set from eBay £40 landed next day delivery. 14mm x 1.25.
    I had to file down the end of the tap so that it was a tight fit into a socket, then carefully cut the new thread using a half inch ratchet, no drilling required!
    I had to cut and extend the V-coil insert tool as it was not long enough to reach down in the head.
    Screwed the new v-Coil into position, 1/2 thread lower than mating face of spark plug and then snapped off the fitting tab.
    Hoovered the plug hole out while turning the engine over.
    Fitted the plug, and job done.
    All good
    Audi Nut!!!
  • Knight Rider S4
    • 3541
    Good work...do you have link for ebay item ..is something I always mean to buy
    Steve
    93 S2 Avant Parting
    91 URQ RR
    02 A4 tdi Avant
    • Tonks4x4
      • Nov 2005
      • 3062
      item no: 230457255555
      Audi Nut!!!
        Originally posted by Knight Rider S4
        Good work...do you have link for ebay item ..is something I always mean to buy Cheers Steve
        Here's a better idea. Check your plugs for proper torque (22 lb ft/ 30 Nm) and recheck every so often. Neglect is the cause of this problem.
        • Tonks4x4
          • Nov 2005
          • 3062
          it was a customers car
          Audi Nut!!!
