RS2 ECU into S2 Loom?
  • RS_Rayver
    • Apr 2010
    • 6
    Hi all, I'm currently in the process of fitting an RS2 engine into my S2 coupe but dont have any of the RS loom or ECU. Can an RS2 ecu be used with the S2 loom? If not, can the S2 ecu be remapped upto RS2 Spec?
    any help will be greatly appreciated,thanks for reading,
    Ray.
  • Pirvu Eugen
    • Apr 2007
    • 1978
    • Country: Romania
    What engine you had in your S2?
    • RS_Rayver
      • Apr 2010
      • 6
      the S2 engine is an ABY and the RS2 engine is an ADU.
      • Pirvu Eugen
        • Apr 2007
        • 1978
        • Country: Romania
        Then...the engine looms are identical.
        Goodluck!
        You need to install the rs2 engine and rs2 ecu on your existing loom.
        • Pirvu Eugen
          • Apr 2007
          • 1978
          • Country: Romania
          You can remap your ABY ecu to rs2 spec.
          Search the forum for the tuners wich have done this!
          Success!
          • RS_Rayver
            • Apr 2010
            • 6
            Thanks very much, I'll have a look at the threads regarding tuning the standard ABY ECU up to RS2 spec and decide which is the best route. Thanks again for your help. :-)
            • hoffer76
              • Mar 2008
              • 230
              3 bar map sensor and resistor change then its a choice off chips.
