My crank shaft is damaged (it's where 3rd conrod is connected to crank shaft). Crank shaft is scratshed there. Is there any possibility to repair it or should I put new one?
The 5cyl crank is easy to obtain and they very rarely have any wear. I'd look to replace it with a second hand item. It's also worth getting it crack tested before using it in a rebuild.
I have heard that there isn't any undersize berrings for that engine. My car has about 360 hp and if I repair it then how reliable will it be? I have a place where I can get used crank shaft for about 350 EUR but before I buy it I want to be sure that I can't repair the old one.
