Addressed to all you engine bod's out there... I have a converted 7A head which I am putting onto my AAN, are the exhaust valves different on the 7A as I am skimming / grinding it ready and need to know whether I need new valves or not??
Thanks in advance
Originally posted by S2central.net
Do NOT use 7a ex valves on turbo application. The factory 20vt items are sodium filled to aid cooling.
interesting. what's the benefit of using a 7A head on an AAN bottom end?
C4 A6 AEL avant quattro: daily
TYPE-85 Coupe Quattro:clicky
2.5L GTi engineering RE2500 190hp.180lb Schrick 272 cam C A C 2.5" T304 Exhaust ITG filter
7A heads are good as they have had less abuse than a 20VT head wrt tendency for some cracks near the spark plug holes... 7A head needs fair bit of modification to work on 20VT but its well documented by now. A search here will find it
The old head is still on the car at Tonks4x4 in Mansfield and I live in Newcastle and find it hard to find time to go down and Brian has enough to do so I bought a new head as it was the easiest most efficient option...
