Troubleshooted this for a long time, but running empty soon
This is the case.
After installation of the new turbo etc, the car ran fine. But after a few Gtech runs something happened. Just about 4800-5000 rpm the boost goes of, just like letting the throttle go. No missfire er any other signs. If i ease of the throttle and then floor it again it runs as normal up to the same rpm before boost cuts.
In the added screendump it is very easy to see that the boost drops of when the tps is still at 100% for a while before the throttle is shut.
I've also been thinking of a air leak (IC), but it seem a bit strange since it is keeping the boost for some time before dropping. In 3.rd it helds the boost about 3 sec before it start to drop.
Lowering the boost to about 1.1-1.2 bar and there is no cut.
Here is what i have tried out.
-Was running with manuel boost valve (hallmann adjustable).
-Replaced back to a new N75.
-Was running a forge diverter, now changed to an adjustable valve.
-Tried to block of the diverter, isolated totally.
-Checked the WG diaphrame.
-1,9 bar wg spring.
Other setup:
034 silicone on inlet and boost side.
Gt3071 software from 034 (26 psi).
3" Dp and RS2 Ex man.
3 bar bosch map sensor.
Full Zeitronix package.
So, a faulty MAP sensor, dodgy knock sensor?? but with regards to the map sensor i would expect a faulty reading in the instrument, but it shows almost the same as the zeitronix map sensor (26 psi ich).
Any other hint or tips??
This is the case.
-1,9 bar wg spring.
Other setup:
