Larger fuel pump
  • euro_urs4
    • Nov 2008
    • 267
    • Home: Poland Current: United States
    Larger fuel pump
    is it necessary to change out the fuel pump on the aan motor if going bigger turbo? or will the stock fuel pump flow enough fuel to the motor
  • lind4hl
    • Jul 2008
    • 2465
    depends on setup, what BHP you want to run?
    • GazzaG60
      • 4133
      for me the pump or my aby pump started to drop away after 300 or so. reason i can tell that is injector duty and amount of trimming needed to get it back to where it was.
      afr's went from rising towards 13 to dropping towards 8.
      • euro_urs4
        • Nov 2008
        • 267
        aiming for 500whp using a HX40 7 blade, so most likely have to upgrade im assuming?
