Engine don't start.
  • nemilosu
    • Nov 2008
    • 196
    • Country: Romania
    Engine don't start.
    When is hot, if i stopt the engine, won't start imediatelly.
    if i let cool down about 10-15 min , start very fine.
    why ?
  • spink
    • 4382
    I see you have an AAN in your 200 so its a good possibilty that the cam position sensor is failing
    Checking the codes should tell you a fault with it
    • Nik0las
      • 1345
      • Country: Bulgaria
      Also could be the starter.
      about hall sensor:
