Could anyone please explain what these connectors are for?
  • WidowmakerS2
    • Oct 2007
    • 354
    • Current: Norway
    Hi,
    Tried asking this question before, but didn't get an answer.
    Connectors 13 & 14 for the starter.
    Connectors 11 & 12 for the alternator.
    Trying to get this sorted. Was hoping to start the car up this weekend.
    If at first you don't succeed, destroy all evidence that you tried.
    -CQ 3b "S2".
  • mcandmar
    • Apr 2004
    • 5118
    13 is the starter trigger, (spade connector) switched on by the ignition key. Diagram is a bit misleading as it looks like it connects directly to the battery. Large cable shown behind 13 is the big fat power feed from battery.
    14 i have never seen before, maybe its a power feed for the AC pump?
    11 looks like the alternator 12v supply, round eyelet thats held on with a 8mm nut from memory.
    12 i dont think exists, never seen a spade connector on the back of an alternator.
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
    • s2driveruk
      • 12696
      3b loom to the starter is NLA....
      1992 3b S2 Coupe
      • WidowmakerS2
        • Oct 2007
        • 354
        • Current: Norway
        Tell me about it
        -CQ 3b "S2".
        • WidowmakerS2
          • Oct 2007
          • 354
          • Current: Norway
          Just the sort of reply I was hoping for!
          -CQ 3b "S2".
          • martinjs
            • 3205
            14 connection for short loom to wgfv?
            • WidowmakerS2
              • Oct 2007
              • 354
              • Current: Norway
              Yes, that sounds just about right
              Is the starter grounded to chassis via the sump earth strap?
              -CQ 3b "S2".
              • WidowmakerS2
                • Oct 2007
                • 354
                • Current: Norway
                Would it be okay to run just a single large cable from the battery to the engine bay, lets say to a circuit breaker, and split it there for the starter and alternator?
                -CQ 3b "S2".
