a fairly generla one and looking for some pointers.
I bought my urS4 in October and it felt every bit as quick as 275BHp (MTM remap, 044 pump, stromung exhaust) But i feel its never been quite right since i hit a big puddle (felt like a lake) unavoidable on a B road with a lorry coming the otherway.
A few things which arent quite right in my head.
4th gear at 30mph, put your boot to floor and the digital guage rises to 2.3/2.4, but the live gauge reads 15-16psi. But oddly at say 3500-4000 with foot to the floor, quickly take foot off the accelerator then striaght back on the live guage will rise to 21-22psi and it really goes a good bit more.
Off the mark starts arent really that fast but it really goes once your moving at motorway speeds.
I know i am getting used to the speed but it doesnt fell as punchy as it did before. Still quick but feel more like standard plus a wee bit, But does feel like it is moving when you are at the end of the rev range but not as punchy from say 2-5k
When you start or change gear the revs rise and then drop before settling, it does this through the gears going slowly as well, moves up and down about 500 rpm.
Other than the engine parts above, i have replaced the alternators, PAS, aux belts, pulley, rear track adjusters, ball joints, o/s headlight, new tailgate struts, two front tyres, two front wheel bearings, two SH rear calipers, handbrake cable.
Engine wise with help from KnightriderS2, really insightful day, replaced a few popped off hose at the back of the block, checked for boost leaks, Replaced TB/Ic hose clamps with U clamps, MAF was filthy with oil all over it, gavre it a good old clean (i half suspect this), replaced ****** coil boots (reminds me if Steve is still doing a new batch), replaced soggy K&N filter, coil packs OK.
Any suggestions as to what might be holding back the power.
