Removing turbo?
  • AquaS2
    • 705
    Removing turbo?
    I've got to remove the turbo to make more room to get to the core plugs. Just a quick question if there's anything i should look out for, or not touch? Last thing i want is to be trying to get the turbo off but damaging something else along the way..
    Standard ABY...
    Regards
    Harry
    F I R E U P T H E Q U A T T R O
    1996 S2 coupe aqua green sold
    1990 MK2 Golf gti 16v oak green sold
  • s2driveruk
    • 12696
    if its not been removed before expect there to be a drama somewhere along the way in terms of getting the studs off etc...age and heat do them (or your knuckles) no favours.
    Good luck
    David
    1992 3b S2 Coupe
      You'll need a cut down spanner or half moon spanner for one downpipe to turbo nut, it's a r33t bi-atch
        Jamo beat me to it, but yes some banana spanners are required alright - and plenty of patience on crusted up old exhaust side nuts that rarely co-operate without some sort of drama.
        Be careful with oil and water pipes that you don't ingest any dirt is the only other thing I can think of right now
        • s2driveruk
          • 12696
          yep stubby 15mm spanner will help no end
          1992 3b S2 Coupe
          • AquaS2
            • 705
            Thanks, we'll see how it goes!
