Issues with connections around the turbo, something wrong?
  • Issues with connections around the turbo, something wrong?
    Got a few issues to take care of on my 3b.
    First one is a bit odd. The oil pipe from the Oil filter bracket to turbo isn't a good fit.
    I'm not sure, but i think it's from a S4. (Engine's got return in block btw, strange for a 3b). Looks as though the end on the bottom part of the pipe is bent slightly to little.
    Second one is the evap that is supposed to connect to the hose between MAF and turbo, doesnt seem to fit right.
    Same thing with the resirc valve, seems to be a bad fit. Leads me to believe that the MAF-turbo hose is not for my car, just seems odd.
    Sorry for pic quality, phone
    If at first you don't succeed, destroy all evidence that you tried.
    -CQ 3b "S2".
    That oil pipe has an odd looking bend on the right of the second pic, shouldnt be like that. (S4 is the same as 3b/aby etc).
    I think you have an aby maf hose.
      Ah, goodie.
      So, ABY ans 3b has different types of MAF hose?
      -CQ 3b "S2".
