Help on sensors/electrical on ABY/ADU block
  • AndersS2
    • Sep 2005
    • 1364
    • Home: Norway
    As VagCat is down, can anyone help with what is going where on the holes under the numbers? Im unsure if those I remember is correct.
    1: ? part number?
    2: knocking sensor?
    3: knocking sensor #2?
    4: ? part number?
    5: ? part number?
    6: Big oiltemperature sensor? Part number?
    7: ? part number?
    8: Small oil sensor? part number?
    Picture:
    Anders - S2 Avant Clubsport - 8pots or die!
    No. 2 and 3 are the knock sensors:
    4= nothing AFAIK
    6 and 8 = Oil press senders as shown here:
    (on my AAN, the simple pressure switch (white plastic middle) is mounted in the No. 6 hole and the larger oil pressure sender with two contacts is mounted in the No. 8 position).
    Not sure about 1, 5 or 7 but I think 7 = nothing.
      • AndersS2
        • Sep 2005
        • 1364
        • Home: Norway
        thanks guys!
