Oil in spark plug well
  • mayhemg77
    • Nov 2007
    • 106
    Hi Guys
    I have oil in the first spark plug well, im assuming that there is a gasket halfway down that has perished as it cant see the oil getting in any other way? could someone confirm this and give me some advice on how complex this replacement would be?
    would i need to get a full gasket set or can i get just that specific gasket?
    Lind rgrds in advance
    Graeme
  • Jas11n
    • 5067
    Rocker gasket gone. Specifically the centre part. The gasket comes as a set of 4 parts.
    Two half moon seals for the rear, the main gasket and the centre part that seals around plug recesses.
    About £30 IIRC when I bought one for a recent change (Audi supplied)
    See >>> here for the job of changing it.
    Not that difficult.
    HTH's
    Jase..
    2001 Avus Silver B5 RS4.
    1995 S2 Coupe - sold (sniff)
    • s2driveruk
      • 12696
      yep pretty easy just dont over tighten the bolts on refit or it will start leaking pretty soon. also check the pcv health as it can weep if thats knackered. Oh and good opportunity to change the cap heads to s/steel too ;-)
      1992 3b S2 Coupe
      • Knight Rider S4
        • 3541
        CAm cover gasket which come in two part outside and rings for seals round spark plug tunnel ,
        How to on mikes web page , straight forward job , just make sure you dont over tightening bolts as it wont seal
        93 S2 Avant Parting
        91 URQ RR
        02 A4 tdi Avant
        • Knight Rider S4
          • 3541
          Wow everyones quick off the mark tonight ...
          93 S2 Avant Parting
          91 URQ RR
          02 A4 tdi Avant
          • mayhemg77
            • Nov 2007
            • 106
            cheers jase
            i will d.i.y it then, get the tools oily
            thanks again
            Graeme
            • mayhemg77
              • Nov 2007
              • 106
              yeah and everyone else!
              Where can i get the stainless steel bolts from?
              rgrds
              • s2driveruk
                • 12696
                1992 3b S2 Coupe
                  Could be one of two things gasket in the cam cover is perished or the coil pack boot is perished.
                  Gasket is on the bottom of the cam cover, it's 5 big rubber o-rings linked together in one piece. really simple to change just remove the cam cover and replace it
                  • mayhemg77
                    • Nov 2007
                    • 106
                    im sure its the cam cover gaskets as i have replaced the coilpack recently, ill get this done this weekend,
                    i will obviously need new plugs, is there any sets left available from that group buy?
                    • Jas11n
                      • 5067
                      Where's the oil in the coilpack boot coming from?
                      • mayhemg77
                        • Nov 2007
                        • 106
                        i assumed it would be a gasket in the well as oil cant get in any other way? can it?
                        • Fat Audi 80
                          • 10547
                          If you need coilpack boots, I have two sets left in the group buy... PM me.
                          Cheers,
                          Steve.
                          The Perfectionist
                          • mayhemg77
                            • Nov 2007
                            • 106
                            thanks fat 80, but mine are ok, i need plugs tho, do u know who had the group buy on them?
                            heard there a few still for sale?
                            rgrds
                            • Fat Audi 80
                              • 10547
                              Don't know about plugs I am afraid.
                              The Perfectionist
