s6 aan not starting.Vag com showed codes for camshaft position sensor and rpm sensor.
I changed the rpm sensor and crankshaft position sensors with others from 2 working cars.Changed the ecu.NOTHING.....
I decided to get the car home towed.I put the car in 6 gear and let off the clutch to be abble to charge the batery.After 5km the rpm gauge the car started to move and the engine started(with my ecu,non imo).Stoped the car put his ecu back and it started again.
After a fiew days the car stopped starting again.Only thing left to change is camshaft position s. BUT:if i disconect the cam sensor on my urs4 and i operate starter the engine does not start but the fuel pump is working.At this s6 the fuel pump relay is not working(tried to change the relay).Also cecked the fuses near ecu(s4 has thermal fuses s6 normal ones)
Ecu pin40(Input from Engine Speed Sensor – G28 – V/BK – Also connected to Ch.28 in the A/C head so you can read out RPM in the A/C head) from ecu to sensor showed NO CONECTIVITY.
OE alarm?A friend started the car after closing and opening and cranking 20 times.
A diagram for oe alarm?
THX,
Bogdan
THX,
Bogdan
