converting a 2.0 b4 avant to a 2.8 v6
  • sunny
    • Oct 2007
    • 77
    • Home: India Current: England
    need a bit of help, what bits do i exactly need i wanna keep it 2wd. do i need to change the subframe, would the same 2.0 gearbox mount to the 2.8, ecu, loom....etc
    thankful for any help
    sunny
  • donce
    • Aug 2005
    • 127
    • Country: Lithuania
    yes change ecu and all the stuff. gearbox will be ok. the subframe is different. for the final - dont do it. its not worth. ( or if you have nothing to do, then ok)
    • hermanio
      • Jan 2009
      • 800
      motor mount are different and need to be rewelded, i would not do it.
      5 Cylinder Freak
      • sunny
        • Oct 2007
        • 77
        thanks for the info guys, is it that much of a job to convert
        • sunny
          • Oct 2007
          • 77
          which engine would recommend to put in??? greatful for any pointers
            Why not just buy a 2.8 V6 in the first place, they're not expensive.
            • sunny
              • Oct 2007
              • 77
              i wish i had b4 mate as regreat it now. went a bit far far with the car cosmetic wise. the only thing that let the car down is the engine
              • hermanio
                • Jan 2009
                • 800
                5 cylinder will fit straight in. 2.3 20v 7a has almost the same horsepower as an 2.8 v6, but i would not do it when you dont have quattro...
                5 Cylinder Freak
                  1.8t
                  • sam80quattro
                    • Oct 2006
                    • 1496
                    x2 for the 1.8t
                    • donce
                      • Aug 2005
                      • 127
                      1.8 t if stock or almost stock is ****. it doesnt make much power,so aint worth the money. if you want power - put 20v I5 turbo. if you want just faster car than now - put v6 2.8 . personaly i didnt like 7A, cos it doesnt have low torque, which v6 does have. so 2.8 is more fun in the city. but like all the people said, fwd is bad situation
                        2.8 30V from a B5 or V8 from an A8
                        • gavs20v
                          • Sep 2004
                          • 3057
                          Sunny, is this the estate that was at the westside meet? Get some pics up !!!
                          Engine wise all depends on budget and how much work you're prepared to get into. Anythings do able
                          cheers
                          Gav
                          S2 Cabriolet.........
                          • istoo
                            • Mar 2006
                            • 408
                            7A would suit a FWD car a lot better than an AAH. I have driven a 2.8 FWD and its a handful, the revvy nature of the multivalve suits a FWD car imho.
                            That is unless you install a front diff.
                            • sunny
                              • Oct 2007
                              • 77
                              thnaks for the replys
                              Rusty 1.8t
                              would be nice but gotter be 5 or 6 pot
                              Rusty 2.8 30V from a B5 or V8 from an A8
                              V8 that was the first thing i looked at, alot of works involved
                              gavs20v Quote:
                              cheers
                              Gav
                              thats the car matey ill get some pics up, but had a good think and gonna go down the s2 route, will take a while longer but that would proper complete the car
