cam belt
  • kelys
    • Jan 2010
    • 71
    • Country: Denmark
    cam belt
    Hi
    I have a problem with my cam belt. Its not running in center of cam sprocket.
    any idea why. camsprocket adjustabel from hans dhalbaeck. Steel sprocket from faheemo ecogadgets. New belt and new tension wheel.
    Did you remember to fit the diamond washer inbetween the sprocket and front pulley?
    • repo
      • Dec 2004
      • 893
      Diamond washer?
      • kelys
        • Jan 2010
        • 71
        • Country: Denmark
        Hi Jamo.
        What is a diamond washer
        • kelys
          • Jan 2010
          • 71
          • Country: Denmark
          Hi Jamo
          I found the diamond washer.
          Thanks very much. It works
            Originally posted by repo
            Diamond washer?
            That washer cost about £30 so the forum reckon it's made from pure diamonds
            • Faheemo
              • Feb 2005
              • 544
              • Country: South Africa
              I really taught it was coated with diamond dust ! ( even had a close look to see the dust ! )
              It's just a joke ?
              S2 Coupe fully built.
              10.9 1/4mile 0-100 in 3.5secs
              Precision 6262 turbo
              The Green Monster
              • GazzaG60
                • 4133
                oh the washer. the same washer i lost after putting the belt on and it hitting the cover and then bought same washer for 26 quid plus vat then when fitting it found original said washer used as a washer on crank pulley bolt.
                major fail that one was.
