The Coupe has been laid up for the last 3 weeks... The battery keeps going flat and I thought it maybe the same issue I had with the Golf... IE the head unit seems to like a switched and a non switched power supply... But not had time to sort it as I've had other stuff to sort first..
So yesterday decided to fit the DS2500 pads that have just arrived.... so whilst doing that I put the battery on to a trickle charge... then got down to doing the pads...
But As soon as 10 mins had passed with the charger in place... with the bonnet up and a wheel off the after run fan on the rad started to work...
Thought this has to be odd as the car hasn't even been started in 3 weeks... So now I'm thinking could this be the reason for the battery going flat?????
Anyone got any suggestions?? Could I have a faulty relay/sender unit somewhere or is this normal... Can't be surely???
What can I check???
What can I check???
