Bottom end build up
  • euro_urs4
    • Nov 2008
    • 267
    • Home: Poland Current: United States
    Bottom end build up
    Just wondering what else is recommended to be replaced when going for 500whp or so other than rods and pistons , like rod bearing or studs and sonforth what do you guys recommend replacing and do I get performance parts or stock with work
  • GazzaG60
    • 4133
    arp studs
    new pumps
    good new bearings.
    rods and pistons.
    • euro_urs4
      • Nov 2008
      • 267
      Originally posted by GazzaG60
      arp studs
      new pumps
      good new bearings.
      rods and pistons.
      thats what i had in mind thanks if any one elses suggests more, the more help would be great thanks
        Oil pump I wouldn't necessarily replace it. Open it up check for wear if it's o.k grease with redline and refit.
        For that power you will need arp head studs as well
        Get the crank assembly balanced also whilst it's all out
        • euro_urs4
          • Nov 2008
          • 267
          already have arp head studs, should i also get arp bottom end studs,
            I did on my build but the OEM bolts are very good also so it's not a must do. They must be replaced either way as they are stretch bolts.
            • jevrem
              • Feb 2007
              • 140
              • Country: Serbia
              How much power can stock pistons take?
              Audi URS4 1992. 2.2L 169kw
              www.audiclubserbia.com
              • vcosmin
                • Apr 2008
                • 644
                • Country: Romania
                It depends, but i think that 500hp is safe , there are user runing 700hp with stock piston, on e85 , and with good software.
                • GazzaG60
                  • 4133
                  i run stock pistons, skimmed down. scat rods, new rod bearings. original crank ones. original rings no honing of block for changes.
                  i didn't remove the crank. i left it in.
                  even with just the rods and pistons weight matched the engine feels better for it. also the pistons a little lighter for it too.
                  have had no issues for 2 years running. 20k miles. currently runnnig 1.9bar on sc6152E. you can guess the hp. i wouldn't know but its pretty fast.
