Still a non runner
  • tyler
    • Jun 2010
    • 38
    maybe a weird one but is the key chipped? if so try the spare my mates golf had a very similar problem he changed loads before he figured it was the key
    • Polish
      • Feb 2008
      • 126
      just checked the spare key and it looks like there is no chip in it
      • Gazjen
        • Oct 2008
        • 223
        Sorry I don't get your post
        So with the sensors swapped round your saying that the fuel relay didn't come in?
        If it did your sensors are fine if it didn't the one that was originally reading the pin is toast
        URQ 20vt converted
        80 quattro saloon with on going a V8 transplant
        • Polish
          • Feb 2008
          • 126
          Found that the reason that the relay wasnt pulling in was that the plug was not in the ecu properly changed both sensors and is exactly the same the relay now pulls in am going to check compressions today fingers crossed they are ok
          • Polish
            • Feb 2008
            • 126
            I NOW KNOW WHATS WRONG Its Spun The Botom Pully no key in the crank got the new one today will fit ovwer the weekend to see what if any damage it has caused
            • Gazjen
              • Oct 2008
              • 223
              At least you know what it is now, you might be lucky
              URQ 20vt converted
              • Polish
                • Feb 2008
                • 126
                Belive me i have everything crossed its a bit like watching England play
                • LHD_Kid
                  • May 2006
                  • 3696
                  #38
                  Bingo.....
                  Well done.... hopefully no damage caused......... fingers crossed...
                  • Polish
                    • Feb 2008
                    • 126
                    Fitted the New Pully and it has good compression on all cylinders 210 psi but its not running right seams to be over fueling any ideas?
                    • saltinot
                      • May 2004
                      • 1946
                      #40
                      Pressure regulator. I've had a couple of cars in the garage that exhibited strange starting and running behaivior which turned out to be the pressure reg. I thought they pretty much never failed, but now I always conisder it when diagnosing.
